GDL objects with adjustable materials
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-07-21 07:38 AM
‎2011-07-21
07:38 AM
Your help welcomed! Thanks!
12 REPLIES 12
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-08-22 04:51 PM
‎2011-08-22
04:51 PM
Check the GDL Reference Guide:
You have to have a file called MASTER_GDLxxxxxxxxx.gdl
In the place of xxxxxxxxx you can put any characters so the name of the file will be e.g. MASTER_GDL-OfficeMaterials.gdl
This file must be loaded in the loaded libraries.
You can edit this file in Notepad, it is a text file, with the GDL extension.
In this file you can use any of the DEFINE commands of GDL to define fills, materials, line types, textures etc.
These DEFINE commands are covered in the GDL Manual PDF on pages 196-212
Their result is when you reload libraries and a library contains a MASTER_GDL... file, the content of the file is executed, and if there are those DEFINE commands, the attributes defined in the MASTER_GDL file will be added to the attribute set of the project.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-08-23 01:30 PM
‎2011-08-23
01:30 PM
Thank you very mutch laszlonagy and all the other people who replayed.
I am very new to GDL so this is very helpful. If its possible, can you post a example? It is a little bit easy for me to understand now in the beggining.
Thank you very mutch.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-08-23 01:44 PM
‎2011-08-23
01:44 PM
The examples are there in the GDL Reference Guide PDF.
I copied one example:
Note that the lines starting with ! are comments.
So the real script is:
DEFINE MATERIAL "water" 0, 0.5284, 0.5989, 0.6167, ! surface RGB [0.0..1.0] 1.0, 0.5, 0.5, 0.9, ! ambient, diffuse, specular,transparent ! coefficients [0.0..1.0] 2.0, ! shining [0.0..100.0] 1, ! transparency attenuation [0.0..4.0] 0.5284, 0.5989, 0.6167, ! specular RGB [0.0..1.0] 0, 0, 0, ! emission RGB [0.0..1.0] 0.0 ! emission attenuation [0.0..65.5]
DEFINE MATERIAL "water" 0, 0.5284, 0.5989, 0.6167, 1.0, 0.5, 0.5, 0.9, 2.0, 1, 0.5284, 0.5989, 0.6167, 0, 0, 0, 0.0So if you paste this into Notepad, save it as MASTER_GDL-1.gdl for example, then place this file into any of your loaded libraries, reload the libraries, the new material will be there among your materials.
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
