GLOB_ID to any parameter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-10-26
03:58 PM
2025-02-05
12:23 PM
Aruzhan Ilaikova
How do i link GLOB_ID with another parameter?
I want my parameter to copy from GLOB_ID. So I can edit my "GLOB_ID" in schedules.
- Labels:
Library Part Maker
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-10-26 05:27 PM
So you have to simply list the "Element ID" in the Schedule and you can modify its value in Schedules. No need for this workaround.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-10-27 10:31 AM
laszlonagy wrote:Thank you 😃 But could I get the Element ID to my Interface?
The GLOB_ID global parameter of GDL returns the value that you set in the ID field in the Tags and Categories panel of an element.
I just like to write this code:
UI_OUTFIELD "Littera:", xIf[3],yIf,yText,20,1 UI_INFIELD "GLOB_ID", xIf[4],yIf-5,105,20 : yIf = yIf+yIfDiffBut which code should I use there?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-10-27 12:14 PM
It will return the value of the Element ID of the element. But you can not set the value of the GLOB_ID in any way.
You can only set the Element ID in the ID field in the Tags and Categories panel.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-10-27 01:57 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-04-21 04:30 PM
Hi there,
Does GLOB_ID still works the same in AC26?
you still cant set ID to change by variable?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-04-21 05:33 PM
I use GLOB_ID and then split the string and set a few parameters, then I can control the entire object with the id
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-04-26 01:31 PM
Yes, it still works the same way.
So, if I understand your request correctly, you would like to be able to specify the value of the Element ID by a formula or expression, and not have to enter it manually.
I can think of two routes nowadays:
1. Element ID Manager - this can change Element IDs based on a few simple criteria and rules. This has been available in Archicad for many years but it is limited in what it can achieve.
2. Python - you can use Python scripts in Archicad to renumber Element IDs. I think Python is available for users with SSA/Forward. and There are some examples on this page: https://graphisoft.com/downloads/python#try
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-04-26 02:49 PM
Yeah OK thank you for replay.
I was hoping to make a label that shows GDL variable from associated object.
