‎2020-05-17 05:34 PM
! Text Rotation - Readable / Always Horizontal / Align with Symbol
r = request ("View_Rotangle", "", _angleViewRot)
! Actual rotation of the 2D symbol:
_totalRotate = (SYMB_ROTANGLE + _angleViewRot) MOD 360
! Count the number of transformations of the
! coordinate system in different cases
_nTrans = 0
if iTypeTextRotation = 2 then ! Readable
if (_totalRotate > (90 + EPS) & _totalRotate < (270 + EPS)) then
rot2 180
_nTrans = _nTrans + 1
endif
else
if iTypeTextRotation = 1 then ! Horizontal
rot2 _totalRotate * (SYMB_MIRRORED - not(SYMB_MIRRORED))
endif
endif
! Text Position - USING "GLOB_SCALE/50" TO MAKE POSITION THE SAME ON ALL SCALES
! THE "/50" IS BECAUSE I WAS DRAWING ON THE 1:50 SCALE AND NEEDED THING TO BE ON THAT PROPORTIONS
ADD2 0.06*GLOB_SCALE/50, 0.13*GLOB_SCALE/50
! MOVABLE HOTSPOTS
unID=1
!_________________________moving it horizontally
hotspot2 0,verti2,unID,horz2,1+128 : unID=unID+1
hotspot2 -1,verti2,unID,horz2,3 : unID=unID+1
hotspot2 horz2,verti2,unID,horz2,2+256 : unID=unID+1
!_________________________moving it vertically
hotspot2 horz2,0,unID,verti2,1+128 : unID=unID+1
hotspot2 horz2,-1,unID,verti2,3 : unID=unID+1
hotspot2 horz2,verti2,unID,verti2,2+256 : unID=unID+1
DEL 1
! TEXT ITSELF
TEXT2 horz2+0.05*GLOB_SCALE/50,verti2+0.1*GLOB_SCALE/50,txti2
! Delete transformation after Text Rotation
del _nTrans
‎2020-05-17 05:38 PM
