‎2019-12-18 08:58 PM
Solved! Go to Solution.
‎2020-01-12 07:30 AM
‎2019-12-18 09:17 PM
‎2019-12-19 03:28 PM
‎2020-01-12 10:25 AM
LaszloNagy wrote:Reading what Barry wrote I realize I might have misunderstood the question so Barry has the right answer.
There are probably several ways of going about it.
Here is one: place a Column there the Building Material of which is higher than those of the Wall's Building Materials. Then the Column will cut itself out of the Wall's geometry.
Place the Column onto a hidden Layer so it does not appear in the model, but still cuts the Wall.
