ā2016-03-29
10:31 PM
ā2023-05-24
10:47 AM
Rubia Torres
Solved! Go to Solution.
ā2021-02-06 11:25 PM - edited ā2023-06-01 10:44 PM
Jesse wrote:
Why don't we have these door options for the USA library?
Hi Jesse,
Sorry I didn't see Brett's post 5 years ago to reply then. We have access to these doors and many more library parts... via an important part of the object settings dialog that will open up a lot of possibilities for you.
The quick answer to Brett's 5 yearr old question is: yes, we can have bypass doors for closets (etc).
Open the Door Settings dialog and type "Sliding Door" in the search field. The internet is searched along with all loaded libraries. You'll see downloadable library parts identified by a stylized globe icon in the lower right. Here, I've selected the "Sliding Door" part from BIM Components. Click "Download and Embed" to download it into the embedded library for the active project.
In placing the object, you'll see lots of options for number of leaves and which ones can slide. I picked "2 Sliding Leaves" to give me a bypass door as in the original question in this thread. You'll see that like many parts, there is a drop-down text option, and the same option is shown graphically on another panel.
ā
ā
ā
Finally, when you view the door in plan or in 3D, you'll see that each movable leaf has an editable hotspot. This allows you to slide the leaf open to the desired position for the 2D or the 3D/Elevation representation.
Hope this helps! š
ā2016-03-29 10:56 PM
ā2016-05-25 02:34 AM
ā2019-07-02 11:26 PM
ā2019-07-03 03:31 AM
ā2021-02-05 10:54 PM
ā2021-02-06 10:37 PM
Hi Jesse,
ā
ā
ā
Hope this helps! š
