2020-11-04 07:46 PM
Solved! Go to Solution.
2020-11-11 02:05 AM
2020-11-05 02:32 AM
2020-11-05 03:39 AM
2020-11-05 03:48 AM
2020-11-05 07:23 AM
Barry wrote:
Turn on the 'Segments and Nodes' so you can select the segment that has the inner post too close to the corner.
Select the segment and reverse the pattern.
2020-11-10 12:43 PM
2020-11-11 02:05 AM
2020-11-11 09:49 AM
Barry wrote:I love you Barry!
Mats,
Just watching your video.
At about 2.30 you don't need to add the double post at the corner.
Leave it as a single post.
When you place the railing you place a node 250mm from the corner - this will place a single post there.
If you have an existing railing (like you do) edit the reference line and insert a new node 250mm from the corner.
So basically, every where you want a post, you add a node to the railing reference line.
The inner post and balusters will spread between these main posts and you can edit each segment to get them just how you want.
2020-11-11 10:10 AM
2020-11-11 10:50 AM
