‎2020-11-04 07:46 PM
Solved! Go to Solution.
‎2020-11-11 02:05 AM
‎2020-11-05 02:32 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
‎2020-11-05 03:39 AM
‎2020-11-05 03:48 AM
‎2020-11-05 07:23 AM
Barry wrote:
Turn on the 'Segments and Nodes' so you can select the segment that has the inner post too close to the corner.
Select the segment and reverse the pattern.
‎2020-11-10 12:43 PM
‎2020-11-11 09:49 AM
Barry wrote:I love you Barry!
Mats,
Just watching your video.
At about 2.30 you don't need to add the double post at the corner.
Leave it as a single post.
When you place the railing you place a node 250mm from the corner - this will place a single post there.
If you have an existing railing (like you do) edit the reference line and insert a new node 250mm from the corner.
So basically, every where you want a post, you add a node to the railing reference line.
The inner post and balusters will spread between these main posts and you can edit each segment to get them just how you want.
‎2020-11-11 10:10 AM
‎2020-11-11 10:50 AM
