on
2021-07-28
12:33 PM
- edited on
2023-05-15
02:56 PM
Noemi Balogh
For an overview of the Custom Component feature, see Create Custom Components:Example Workflows
In this Tech Tip we will show how to create a custom object component, in this case a custom door panel for a Basin Cabinet
We placed the Basin Cabinet 25.gsm file onto the Floor Plan. Here is how it looks in 3D:
We want to measure the dimensions of the cabinet door panel, so let's create an Elevation or Interior Elevation line on the Floor Plan in front of the Cabinet. The line should be parallel to the face of the Cabinet because we want to get an orthogonal elevation view of it.
Measure the size of one door panel. (Use the Measure Tool, the Tracker or the Coordinate Box.) This size will be your custom panel size. In our example, this is 447mm wide by 747 mm high.
Go back to the Floor Plan, and using Slabs, draw the geometry of one Door Panel. In our case, we will create a sort of a Prairie Style panel. Assign them the pens and materials you wish to see in 2D/3D.
Select all elements just drawn.
Use the File > Libraries and Objects > Save Selection as... > Cabinet Door... menu command to save these elements.
In the next dialog, you can give the new panel a name and choose it's location. Press save to finalize.
Select the Basin Cabinet Object on the Floor Plan or 3D, and go to its Settings Dialog.
From BASIN CABINET SETTINGS tab, Choose Door..., Then from the Door Styles Menu, pick Custom...
Click the right-pointing arrow to the right of the Custom Panel Name, and choose the name you have picked for your door panel.
Click OK to accept changes and go to the 3D Window to see the result.
Now available as a built-in feature of Archicad 24 Update 3, PARAM-O makes the process of creating custom objects easier and more intuitive.
Read more about PARAM-O here.
Hi Nouras,
Is the terminology changed on AC25? I don't see Door Styles, guessing it is replaced by Front Panel. Will that be correct?
However, even I followed all the steps suggested, there was nothing available to be selected within "Front Panel"/"Panel Style".
I've checked "Embedded Library" and confirm the custom-made cabinet door is inside Embedded Library. I have even Reload & Apply the library and tried again, but still no luck.
Any advice will be appreciated. Thank you.
Eddie
AC25 build 5010
Hi @Eddie W,
I could quickly reproduce the steps described above in Archicad 25 INT version. In "Door Styles", you need to go to the bottom of the list and select "Custom ..." to be able to assign your unique design from the Embedded Library. Still, if you cannot replicate these steps on your project, please share screenshots with us.
I look forward to news.
Rubia Torres
Junior Customer Engagement Expert | GRAPHISOFT SE
Need help refining your modelling skills?
Check our Design category for the best workflow + tips&tricks!
