2023-04-04
03:50 AM
2025-03-27
03:55 AM
How to create slide door with 3 sliding door panels (all sliding)?
Thank you
2023-04-06 02:30 AM
Is there no default library door can do 3 leaves 3 sliding?
2023-04-06 03:36 AM - edited 2023-04-06 03:37 AM
Not that I could see in the default library - 3 panels with 2 sliding or 4 panel with 3 sliding.
I could not see anything with all 3 sliding.
But then I do not use the default library, so I am not totally familiar with it.
So you could look for a 3rd party object.
Or create your own from slabs in plan and save as a door object, or use Library Part maker to help you create an object and also co-ordinate the plan and 3D views.
Also try searching in the door settings for "D3 Sliding"
I see there are a few doors in there that say they are 'by-pass' which to me means all sliding.
Some for USA library and the others I assume for INT (others).
2023-05-10 11:08 PM
I'm having a similar problem finding a slider with more than 3 panels. The "D1 Sliding Folding Multipanel USA" for instance, does it actually switch to a sliding layout or is the "sliding" in the name just to aggravate us?
using AC26 on a Mac.
Thanks
2025-03-26 08:51 AM
Found a new door in the AC28 library that can do this!
2025-03-28 04:08 PM - edited 2025-03-28 04:09 PM
It solves my issues in almost all the projects I'm handling right now. When I saw the update 1 release notes, I was cautiously optimistic, but when I tried it, I was soooo relieved that it actually does what it is supposed to without jankiness. Sometimes it's good to immediately update everything you can. Other times? You get bugs, like I did with Update Preview - that was real pain. Yeah, I know, it was PREVIEW. But it solved some other issues I had, so I had to deal with it.
