How to group objects so that selecting one selects all in group
Espen da Silva
Hi, I'm following a tutorial on grouping, which is quite simple. Select multiple objects > ctrl+g. Then you should be able to select all objects in the group by selecting one of them. But for some reason grouping objects does not do this. The objects change color slightly but when I deselect them and try to select one, only one is selected, an not the group. Is there a reason for this? How do I fix it?
10 REPLIES 10
Patrick M
Mentor
edit > grouping > suspend groups
