Hello all,
I'm creating an object and I've set hotspots in 2D script, but object insists in showing them in 3D Views. I've tried to apply the option "Ac_show2Dhotspotin3D" in different instancies, but it simply doesn't work.
Any suggestions to avoid the issue?
I don't know if it's the only way to do it but if you actually define 3d hotspots (in the 3d script), even as few as just one, then I believe your issue will be solved.
