How to purge non-existent library objects?
I have a project where I used the Cadimage cabinets briefly. I ultimately deleted all of the cabinets, and uninstalled the Cadimage add-on, and then deleted the Cabinet library. However, now, whenever I start the program, I get notified of 20 missing Cadimage cabinet objects, even though these were all deleted. (Find and Select doesn't pick them up, either.) Any idea of what's going on and how to get rid of the error message?
Richard
AC26 (since AC6.0), Win10
18 REPLIES 18
Eduardo Rolon
Did you check the Embedded Library?
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08
another Moderator
Yes, but I'm not sure why that would be relevant. There are no Cadimage cabinet libraries, and there are no Cadimage cabinets in the project. These are phantom missing objects.
Richard
Eduardo Rolon
I don't know how CI works but it may be that it saves each cabinet option that you created as an object in the Embedded Lib same as using "Custom Stair" but since you indicate that they are not there you can check Favorites to see if they are hiding there.
AC29 US/INT -> AC08
another Moderator
Aaron Bourgoin
Richard,
When you open the file, do you get the Cadimage dialog box about Cadimage data in the file? If so, have you untucked the boxes to discard the information?
just making a guess.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
Aaron wrote:
Richard,
No, I don't get that dialog box. (I know which one you mean, though. I get it on many projects.) I'm stumped.
Richard
Eduardo Rolon
Do a "New and Reset"?
AC29 US/INT -> AC08
another Moderator
On an existing large project? It's not an issue for a new plan.
Richard
Eduardo Rolon
Running out of options here since it does not make sense.
Any modules that need updating? or
Update placed drawings and schedules?
AC29 US/INT -> AC08
another Moderator
Jeff Kogut
We has some Cadimage 'residue' for a while after one user tried it out. I think there was a single node-like dot in the Schedules area of the view map that we deleted. You may have more similar items.
AC19-23 | Win10 Pro | i7-8700K | Quadro P600 | 500gb 960 EVO M2 | Dual 28" 4k Samsung U28E590
