2008-11-15 06:09 PM
2008-12-13 10:46 PM
Peter wrote:Thanks again, Peter - object and PDF article are a zip download in the Depository link given. Unless I messed up the upload.
Is there any way I can obtain your XFORM object
2008-12-13 11:38 PM
2008-12-14 12:08 AM
2008-12-14 01:28 AM
2008-12-14 02:00 AM
2008-12-14 02:17 AM
2008-12-14 04:39 AM
Peter wrote:Of course! I did a Spotlight search and couldnt find anything else other than an early version of skewer (not parametric) called 'xform test'. Getting old and forgetful stinks.
Thank you for talking to me.
2008-12-14 04:45 PM
2008-12-14 08:13 PM
2008-12-14 08:32 PM
Subject: [GDLTalk] XFORM (was koordinates) Date: July 13, 2001 12:33:36 PM MDT To: GDLTalk > Following the coordinates thread, could anybody enlighten me on how > XFORM is used? > > Laurent Godel Hi Laurent, Below is an explanation of XFORM in the form of an annotated 3D script. Not sure if that is what you wanted? Regards, Karl ------------> Copy and paste the following into a 3D Script <--- ! XFORM Overview and Demo ! Karl Ottenstein ! July 13, 2001 ! Laurent asked about how the XFORM command is used in GDL. This object ! gives an overview, demo, and some references to textbooks at the end. ! Representing a point as a vector (x, y, z), one can apply matrix algebra ! in order to move (translate), scale, or rotate that point. According to ! Foley and van Dam (ref at end), the concept of homogeneous coordinates ! originated in geometry in 1946 by E. Maxwell at Cambridge. Homogeneous ! coordinates, and their transformations, extend a point vector with an ! additional scale factor - so (x, y, z) becomes (x, y, z, 1) ! The homogeneous transformation matrix for translation only is: ! 1 0 0 0 ! 0 1 0 0 ! 0 0 1 0 ! dx dy dz 1 ! ! So, with dx, dy, dz as 2, 4, 6 [original said "3, 6, 9" - no idea where that came from], similar to ADD 2, 4, 6: ! 1 0 0 0 ! 0 1 0 0 ! 0 0 1 0 ! 2 4 6 1 ! ! Multiply a point (x, y, z, 1) in homogenous coordinate space ! (the extra 1) with the above matrix: pt * M and you get ! (x+2, y+4, z+6, 1) - a "translated" (shifted) point. ! ! Read DOWN the matrix columns as entering data for the XFORM, and ! leave off the last column of the 4x4 matrix above. XFORM 1, 0, 0, 2, 0, 1, 0, 4, 0, 0, 1, 6 ! Make an asymmetric block in order to see what's going on BLOCK 1, 4, 8 DEL 1 ! The homogeneous transformation matrix for scaling only is: ! sx 0 0 0 ! 0 sy 0 0 ! 0 0 sz 0 ! 0 0 0 1 ! ! So, with sx, sy, sz as 2, .5, .5, similar to MUL 2, 0.5, 0.5 ! you have: ! 2 0 0 0 ! 0 0.5 0 0 ! 0 0 0.5 0 ! 0 0 0 1 ! ! Multiply a point (x, y, z, 1) in homogenous coordinate space ! by the above matrix: pt * M and you get ! (x*2, y*0.5, z*.05, 1) ! ! Read DOWN the matrix columns as entering data for the XFORM, and ! leave off the last column of the 4x4 matrix above. XFORM 2, 0, 0, 0, 0, 0.5, 0, 0, 0, 0, 0.5, 0 ! Make a sphere in order to see what's going on SPHERE 3 DEL 1 ! Before we proceed to rotation - let's combine translation and scaling, ! using the same numbers as above. Notice that the XFORM below replaces ! one ADD and one MUL at this point: ! Translate and scale together XFORM 2, 0, 0, 2, 0, 0.5, 0, 4, 0, 0, 0.5, 6 ! Make a sphere in order to see what's going on SPHERE 3 DEL 1 !The transformation matrix for rotation "a" degrees about the Z axis is: ! cos(a) sin(a) 0 0 ! -sin(a) cos(a) 0 0 ! 0 0 1 0 ! 0 0 0 1 !For "a" degrees about the X axis: ! 1 0 0 0 ! 0 cos(a) sin(a) 0 ! 0 -sin(a) cos(a) 0 ! 0 0 0 1 !And, for "a" degrees about the Y axis: ! cos(a) 0 -sin(a) 0 ! 0 1 0 0 ! sin(a) 0 cos(a) 0 ! 0 0 0 1 ! So...let's rotate a block ! about the Y axis 30 degrees...same as ROTY 30 ang = 30 cosa = cos(ang) sina = sin(ang) XFORM cosa, 0, sina, 0, 0, 1, 0, 0, -sina, 0, cosa, 0 ! Make an asymmetric block in order to see what's going on BLOCK 1, 4, 8 DEL 1 END ! ! Note that the matrices are combined by multiplying them together, ! giving a new 4x4 transformation matrix. Any number of transformations ! can be combined into one final matrix - represented by a single ! GDL XFORM. Email me if you want me to post an explanation and ! example. ! ! This is probably not that useful for most GDL programmers, but ! would be very handy for API developers. (Picture an add-on where the ! user has sliders to rotate, scale and translate an object. The final ! settings could be saved as a single XFORM.) ! References ! ! These books are dated, as am I. No doubt there are newer editions, ! and even other, newer books out there now. Two of them were ! classics, and I expect still are. ! ! Foley, J. D. and van Dam, A. Fundamentals of Interactive Computer ! Graphics. Addison-Wesley (1982) 664 pages. This was THE book to ! have - there must be a newer edition. ! ISBN for this edition 0-201-14468-9. ! ! Giloi, Wolfgang K. Interactive Computer Graphics. ! Prentice-Hall (1978) 354 pages. ! ! Harrington, Steven. Computer Graphics: A Programming Approach. ! McGraw-Hill (1983) 448 pages. ! ! Newman, William M. and Sproull, Robert F. Principles of ! Interactive Computer Graphics, 2nd Edition. ! McGraw-Hill (1979) 541 pages. This was the bible for graphics ! when I was in school. ! ! Karl Ottenstein, July 2001.
