2017-09-22 08:06 AM
2017-09-24 02:17 AM
In AC21 it is detailed on Page 450 of the GDL Reference Guide.REQUEST{2} ("Building_Material_info", name_or_index, param_name, value_or_values)Returns information in the given variable(s) on a parameter of the specified building material. Expression returns 0 and contains dummy return values
(emtpy string or 0) if used in parameter script, causing additional warning. Possible building material parameter names corresponding to parameters of
the building material definition:
param_name:
"gs_bmat_id": building material id
"gs_bmat_surface": building material surface index
"gs_bmat_description": building material description
"gs_bmat_manufacturer": building material manufacturer
"gs_bmat_collisiondetection": building material participates in collision detection (0 or 1)
"gs_bmat_intersectionpriority": building material intersection priority
"gs_bmat_cutFill_properties": building material cut fill properties (cut fill index number, cut fill foreground pen index number,
cut fill background pen index number)
"gs_bmat_physical_properties": building material physical properties (thermal conductivity, density, heat capacity, embodied
energy, embodied carbon)
Examples:
REQUEST{2} ("Building_Material_info", "Brick", "gs_bmat_id", id)
REQUEST{2} ("Building_Material_info", "Brick", "gs_bmat_surface", index)
REQUEST{2} ("Building_Material_info", "Brick", "gs_bmat_physical_properties", thermalConductivity, density, heatCapacity, embodiedEnergy, embodiedCarbon)
2017-09-25 03:23 AM
REQUEST{2} ("Building_Material_info",SLAB_BMAT_NAME,"gs_bmat_id",id1)
REQUEST{2("Building_Material_info",SLAB_BMAT_NAME,"gs_bmat_man
facturer",id2)
REQUEST{2} ("Building_Material_info",SLAB_BMAT_NAME, "gs_bmat_description",id3)
2017-09-26 09:28 AM
2019-01-09 07:02 AM
