2024-10-17
10:55 AM
2024-10-17
10:30 PM
Hi!
I cant edit my fiber insulation on archicad. I can stretch it, but cant edit the angles.
Under the "custom settings" option, nothing shows up.
Please someone help me!
Operating system used: Mac Apple Silicon 14 sonoma
2024-10-17 11:07 AM
If you mean edit the angle at the ends for a corner wall, then that object probably can't do it.
It is version 17 which is 11 years old now.
I just looked at the equivalent in 25 and it has moveable hotspots to adjust the end angles.
2024-10-17 11:15 AM
Thank you for your reply. If I search "fiber insulation" this is the only option that shows up, although I use Archicad 26.
Any suggestion how to fix this?
2024-10-17 11:17 AM
Nvm. I found the solution. If I search in my language the latest version shows up. 😄
2024-10-17 11:21 AM
If you have the default library loaded, there should be an object called 'Fiber Insulation 26'.
