Learn more
I need a bus GDL object
Does anyone have or know where I can find a model bus? Such as a Greyhound, or Metro, as well as any freight trains and Light rail vehicle models? Can ya tell I am in transportation?
Thanks!
8 Replies 8
Try www.archibase.net on the Free 3D Models tab.
Try to find the Construction Equipment Library which was once free at gdlcental.
Just looked at gdlcentral - what has happened with it?! There is some rubbish site at this address that has nothing to do with it?!
Thanks guys.... I did find a bus and a trolley at ArchiBar... is there a method to the madness of object organization? Things just seem to be randomly listed, non alphabetically, non typically...... it is still way cool and I am so happy I found it.
I believe there is also a bus in the 20th anniversary edition library (AC7) which is now here in the object depository under Vehicles > Street & Traffic.
On ArchiBase I think they're listed in the order they are uploaded. There is a pull-down menu to filter different types of objects, or object collections. (make your selection then click on the "filter objects" button).
Thanks!
If you want the busses and trains from the 20th Anniversary library there are three of each. All about 1.2Mb files. I can send them privately to save cluttering up the Forum site.
That would be great.
Philip wrote:
Thanks!
They are also available from the Object Depository.
Look in: Sitework > Street & Traffic
