4hotshoes
I see not fixed window with transom.
There are many configurations of windows, but I need a stacked window or one with a transom to act as one on the plan. The library shows one fixed stacked with an awning, which should be in the awning window folder. Am I missing something? What do users do?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
8 Replies 8
An image of what you are after would be really helpful.
Lingwisyer
Guru
Are you using the US library or the INT library?
4hotshoes
I am using the US library that came with Archicad 23. Images attached. The library part circled is the configuration that I want, but with both fixed. This would be used as in the 3D image.
Todd Oeftger
vistasp
It will, of course, be somewhat different in the US library parts, is there somewhere in the settings where you can change the type of shutter/pane above the transom?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
4hotshoes
Yes. That would be nice. As you can see my previous screenshot that I do not have an option to select the window type above. I have heard that the window and door tools are being worked on. and the US version is less endowed with features.
Todd Oeftger
vistasp
So, doesn't a setting like this, exist in the US library parts?
= v i s t a s p =
bT Square Peg
4hotshoes
No.
Todd Oeftger
Lingwisyer
Guru
There is no other way to get a transom, other than to select and awning window? Wonder who came up with that...
