Incorrect vallues calculated for parameter list
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-07-26 12:15 AM
2011-07-26
12:15 AM
VALUES "ZZYZX" 128", 168", 176", 192" IF ZZYZX < 192" THEN IF ZZYZX < 176" THEN IF ZZYZX < 168" THEN PARAMETERS riserQuantity = 20 PARAMETERS riserHeight=ZZYZX/riserQuantity LOCK "riserHeight" ELSE PARAMETERS riserQuantity = 24 PARAMETERS riserHeight=ZZYZX/riserQuantity LOCK "riserHeight" ENDIF ELSE PARAMETERS riserQuantity = 26 PARAMETERS riserHeight=ZZYZX/riserQuantity LOCK "riserHeight" ENDIF ELSE PARAMETERS riserQuantity = 28 PARAMETERS riserHeight=(ZZYZX/riserQuantity) LOCK "riserHeight" ENDIF !PARAMETERS stringerAngle = ATN(riserHeight/treadDepth) !!Doesn't calculate correct angle PARAMETERS stringerAngle = ATN((ZZYZX/riserQuantity)/treadDepth) !!Calculates correct angle LOCK "stringerAngle" PARAMETERS stringerAngleTan = TAN(stringerAngle)
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-07-26 12:20 AM
2011-07-26
12:20 AM
And a screen shot showing the value displayed in the parameter list and a the same value Using a PRINT command. I would be fine is the parameter values was incorrect, but the part is using the incorrect value elsewhere making geometry incorrect the first time the object is generated.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-07-26 04:13 PM
2011-07-26
04:13 PM
Still not sure why this is happening, but if I remover the riserQuantity variable from the riser height calculation and use the actual value, the angle is calculating properly.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-07-27 08:40 PM
2011-07-27
08:40 PM
I think you should declare the values first,
using the parameters command only
sets the user values and runs occasionally.
For example;
Regards, Juha
LOCK "riserHeight"
ELSE
For example;
... riserQuantity = 20 riserHeight=ZZYZX/riserQuantity PARAMETERS riserQuantity = riserQuantity, riserHeight = riserHeight ...Hope this works / helps.
Regards, Juha
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-07-27 10:11 PM
2011-07-27
10:11 PM
Thanks for the tip, but unfortunately it isn't helping. I think my issue has something to do with the Circular functions. I have added in a parameter (stringerAngle2) that takes the TAN of stringerAngle and calculates the arc tangent. This should give me the original angle, but it is off, and not just a small fraction off. It is the angle from the previous run of the scripts. Something isn't updating properly.
