casse
Help me pls! Incorrect liquid volume calculation of a ceramic brick masonry wall.
Incorrect liquid volume calculation of a ceramic brick masonry wall. I only want the gross value minus the window spans. For some reason, Archicad is already discounting something automatically. For example, a wall in meters of 2.80x3x0.15 = 1.26 m3, the gross is correct, but the liquid shows 1.2465 m3. What is being discounted?
If by 'liquid' you mean 'net' or 'conditional' volume, then they will take into account any end connections or trims to other elements.
