2024-05-15 12:24 AM
Incorrect liquid volume calculation of a ceramic brick masonry wall. I only want the gross value minus the window spans. For some reason, Archicad is already discounting something automatically. For example, a wall in meters of 2.80x3x0.15 = 1.26 m3, the gross is correct, but the liquid shows 1.2465 m3. What is being discounted?
2024-05-15 02:50 AM
If by 'liquid' you mean 'net' or 'conditional' volume, then they will take into account any end connections or trims to other elements.
