Individual door settings in Archicad 28
prebennoer
It must be a bug or..?
In ArchiCAD 28, I can no longer "override" a single door and make one door more detailed than, for example, all other doors?
This is a function I have used repeatedly over time. It seems that detailing is now exclusively controlled via MVO and cannot be done specifically for a single door ?
I think that's a huge drawback if that's the case?
Does anyone have suggestions for another way to solve it?
[Topic title edited by moderator to be more descriptive. Original title "Door settings"]
2 ACCEPTED SOLUTIONS
Hi @prebennoer,
Starting with Archicad 28 Library Update 2, the Global Library will once again include the MVO Detail Level override.
Library Update 2 will be released together with Archicad 28 Update 1 on 11th March 2025.
Later, Library Update 3 will also include MVO related improvement.
Best regards,
Magdolna
Hi Magdolna
That's good news - and the best for today.. 😀👍
Looking forward to..
Thanks for your reply..
Best regards-P
6 REPLIES 6
Ahmed_K
SInce archicad 28 , all settings related to MVO are moved to MVO panel, you cannot control individual elements MVO
Archicad 27
Windows 11 professional
The problem is that, not all settings have been added to the MVO panel, and so there are some settings that you cannot use in the AC28...
This is unfortunately a huge step backwards from previous versions.
The intention is not necessarily bad, but the implementation was not good.
Gábor
Versions 6.5 to 28, AMD Ryzen 9 3900x, 32GB ram, GeForce RTX 2070 super, Windows 10
Thank you for the response! If that's true, it's really a huge setback for ArchiCAD 😳
As a long, long-time ArchiCAD user, it's a feature I've always used.
Why has it been removed?
Are there any alternatives?
Hi @prebennoer,
Best regards,
Magdolna
Hi Magdolna
Best regards-P
Thanks @Magdolna Marosvari  Also please bring back the ability to controle 3D visibility in the object itself
Archicad 27
