Individual door settings in Archicad 28
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2025-02-24
11:10 AM
2025-02-26
04:33 PM
It must be a bug or..?
In ArchiCAD 28, I can no longer "override" a single door and make one door more detailed than, for example, all other doors?
This is a function I have used repeatedly over time. It seems that detailing is now exclusively controlled via MVO and cannot be done specifically for a single door ?
I think that's a huge drawback if that's the case?
Does anyone have suggestions for another way to solve it?
[Topic title edited by moderator to be more descriptive. Original title "Door settings"]
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-02-24 02:47 PM
Hi @prebennoer,
Starting with Archicad 28 Library Update 2, the Global Library will once again include the MVO Detail Level override.
Library Update 2 will be released together with Archicad 28 Update 1 on 11th March 2025.
Later, Library Update 3 will also include MVO related improvement.
Best regards,
Magdolna
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-02-24 02:55 PM
Hi Magdolna
That's good news - and the best for today.. 😀👍
Looking forward to..
Thanks for your reply..
Best regards-P
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-02-24 11:59 AM
SInce archicad 28 , all settings related to MVO are moved to MVO panel, you cannot control individual elements MVO
Archicad 27
Windows 11 professional
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-02-24 12:37 PM
The problem is that, not all settings have been added to the MVO panel, and so there are some settings that you cannot use in the AC28...
This is unfortunately a huge step backwards from previous versions.
The intention is not necessarily bad, but the implementation was not good.
Gábor
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-02-24 12:47 PM
Thank you for the response! If that's true, it's really a huge setback for ArchiCAD 😳
As a long, long-time ArchiCAD user, it's a feature I've always used.
Why has it been removed?
Are there any alternatives?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-02-24 02:47 PM
Hi @prebennoer,
Best regards,
Magdolna
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-02-24 02:55 PM
Hi Magdolna
Best regards-P
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-02-24 03:03 PM
Thanks @Magdolna Marosvari Also please bring back the ability to controle 3D visibility in the object itself
Archicad 27
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
3 weeks ago
- last edited
3 weeks ago
Updated to Archicad 28 Library Update 2 and I'm still not seeing a way to override the MVO for opening lines in 3D.
macOS Sonoma 14.7
Mac Studio (2023)
Apple M2 Max
32 GB Memory
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
3 weeks ago
Same as @Sam_F. I updated to 28.1.0 (INT) and still I am not able to do anything more than earlier...
Thank you,
Mac OS Sequoia 15.3.1.
www.cartaarchitecte.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
3 weeks ago
Hopefully Library Update 3 will restore this functionality. Should never have been removed.
macOS Sonoma 14.7
Mac Studio (2023)
Apple M2 Max
32 GB Memory
