ā2006-01-17 01:24 AM
ā2006-01-17 09:41 AM
DennisG wrote:And/or know how to eliminate it?
Anyone else have this problem?
Dennis
ā2006-01-17 10:12 AM
ā2006-01-17 07:40 PM
F. wrote:I am no stranger to chaos, my friend. Which is why I am scrupulous with Libraries; I place all objects within a Master Library which I load with every project. I also use a job-specific library for job-specific parts.
Sounds a bit like library-chaos.š Have you merged the SCREEN-library to your project? -> Library manager.
ā2006-01-17 10:35 PM
ā2006-01-17 11:52 PM
F. wrote:Thanks F.
Have you extracted the PLA into a folder?
Maybe it needs to write something (text I/O) into a file, which is not found , when you reload?
Is the object proofed for your AC version? What says the reseller of the object?
Does it work with a plain project (new and rebuilt) without any other library? (Duplicate file names)
Just some thoughts about it.
ā2006-01-18 01:02 AM
ā2006-01-18 01:46 AM
F. wrote:Would you believe version 15 Windows?!
Right-click on the object in the explorer -> information. Then on tab info/version: 17 is ArchiCAD 7, 20 is ArchiCAD 8.x, 21 is ArchiCAD 9.
F. wrote:I could not find either phrase in either the 2D or 3D scripts.
If you can look inside the scripts, have a look for (find) GLOB_MODPAR_NAME and NAME_OF_PROGRAM. There have been bugs in AC with this statements. The last one was used to check on which platform the object is running. Maybe this does not work correct. A blind guess.
F. wrote:Is Daniel Lindahl still around? I'll have to check.
Is there no contact eMail adress directly to the author?
ā2006-01-18 08:38 AM
ā2006-01-18 09:13 AM
F. wrote:That sounds like a good idea; now if I can remember where I put that 8.1 Cd...
#15 is ArchiCAD 6.0. Puh.
Maybe you can open the object in AC 8.1 and save it renamed an with a fitting subtype as 8.1 object.
