Infill Screen.lib - Problems
DennisG
Hi there;
I recently downloaded Infill Screen.PLA from Objects Online.
I'm attempting to use the Infill Screen object to create chain link fence models for a parking garage.
I am able to put together a pretty good fence, after inputting lots of parameters; the problem is, when I exit and restart AC, the part shows up as a fuzzy dot on the plan, and can't be found by Library Manager. When I direct Library Manager to the part, I have to start all over again inputting all the many parameters.
Needless to say this is getting frustrating.
Anyone else have this problem?
Much thanks in advance.
Dennis
Dennis Glynn AIA
ArchiCAD-64 23 3003 USA FULL
x64 Clone PC w/Intel(R) Core i7-4790 CPU @ 3.60GHz, 3601 Mhz, 4 Cores, 8 Logical Processors
NVIDIA Quadro K620
16.00 GB RAM
Win 10 Pro x64 based PC
12 REPLIES 12
DennisG
Dennis
And/or know how to eliminate it?
Dennis Glynn AIA
NVIDIA Quadro K620
16.00 GB RAM
Frank Beister
Sounds a bit like library-chaos. 😉 Have you merged the SCREEN-library to your project? -> Library manager.
DennisG
I am no stranger to chaos, my friend. Which is why I am scrupulous with Libraries; I place all objects within a Master Library which I load with every project. I also use a job-specific library for job-specific parts.
So if there is a part, it should be loading.
Thanks for your reply,
Dennis
Dennis Glynn AIA
NVIDIA Quadro K620
16.00 GB RAM
Frank Beister
Have you extracted the PLA into a folder?
Maybe it needs to write something (text I/O) into a file, which is not found , when you reload?
Is the object proofed for your AC version? What says the reseller of the object?
Does it work with a plain project (new and rebuilt) without any other library? (Duplicate file names)
Just some thoughts about it.
DennisG
Thanks F.
Answers, in order:
- The PLA has been extracted.
- "Writing to a file that is not found" fits the description of what's happening.
- I doubt the Object has been proofed for the latest version of 9.0; how can one determine if an object has been proofed for a particular version? But certainly, writing to a file is apretty basic function, and the file/Library tree I'm using is not exotic.
- I have not heard from Objects Online - I have not contacted them directly yet.
- I have not tried working with loading only with this object to the PLN file. Not sure what would happen.
Thanks for you help!
Dennis
Dennis Glynn AIA
NVIDIA Quadro K620
16.00 GB RAM
Frank Beister
Right-click on the object in the explorer -> information. Then on tab info/version: 17 is ArchiCAD 7, 20 is ArchiCAD 8.x, 21 is ArchiCAD 9.
If you can look inside the scripts, have a look for (find) GLOB_MODPAR_NAME and NAME_OF_PROGRAM. There have been bugs in AC with this statements. The last one was used to check on which platform the object is running. Maybe this does not work correct. A blind guess.
Is there no contact eMail adress directly to the author?
DennisG
Would you believe version 15 Windows?!
I could not find either phrase in either the 2D or 3D scripts.
Is Daniel Lindahl still around? I'll have to check.
Thanks again for your help!
Dennis
Dennis Glynn AIA
NVIDIA Quadro K620
16.00 GB RAM
Frank Beister
#15 is ArchiCAD 6.0. Puh.
Maybe you can open the object in AC 8.1 and save it renamed an with a fitting subtype as 8.1 object.
DennisG
That sounds like a good idea; now if I can remember where I put that 8.1 Cd...
Dennis Glynn AIA
NVIDIA Quadro K620
16.00 GB RAM
