Llian
Insulation Object
I found this in the library folder but it doesn't allow me to stretch to size. Does anyone has s stretchable insulation object to share?
Thanks
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
4 Replies 4
Stress Co_
I Assume you're using "DET_ Batt_Insulation 19"
Try "Fiber Insulation 19"
Marc Corney, Architect
Red Canoe Architecture, P. A.
Llian
Thanks Marc,
All I see in my library folder is just one. Would you be able to share what you got with me? I really do need the cut one for teh edge of the joist and roof.
Do a search for "Insul" as Marc showed in his image and you will find all insulation objects available to you in your library and on BIMComponents (if there are any there).
Llian
Ah yes, I found them...thanks so much!
