Insulation Object
Llian
I found this in the library folder but it doesn't allow me to stretch to size. Does anyone has s stretchable insulation object to share?
Thanks
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
4 REPLIES 4
Stress Co_
I Assume you're using "DET_ Batt_Insulation 19"
Try "Fiber Insulation 19"
Marc Corney, Architect
Red Canoe Architecture, P. A.
Llian
Thanks Marc,
All I see in my library folder is just one. Would you be able to share what you got with me? I really do need the cut one for teh edge of the joist and roof.
Lilian Seow
Do a search for "Insul" as Marc showed in his image and you will find all insulation objects available to you in your library and on BIMComponents (if there are any there).
Llian
Ah yes, I found them...thanks so much!
Lilian Seow
