Issue Date Autotext - Work in Progress
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-09-04 09:24 AM
Is there a way to change the format of the
In full, it does not fit in my title block as there is only space for a short hand date, resulting in it covering the drawing number...
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-09-24 07:02 AM
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-09-09 02:24 PM
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-09-09 02:56 PM
This is the snippet of code I use to substitute "W.I.P." for "Work in Progress":
If RevOrDoI = "Revision Manager" Then If LayoutRevHistoryDA[vardim1(LAYOUT_REVISION_HISTORY)][4] = "Work in Progress" Then ! 28 Text2 0, -Text_Y*.5, "W.I.P." Else Text2 0, -Text_Y*.5, LayoutRevHistoryDA[vardim1(LAYOUT_REVISION_HISTORY)][4] EndIf EndIfIt works correctly for the placed Object, but gives an error message "Unitialized variable at line 28 in the 2D script of file Revision Name and Date.gsm. (rev date)" when the Object Settings dialog box is opened. Line 28 is marked in the code. The Object is placed on a Master Layout. I never could figure a way to eliminate the error message, which is a minor annoyance.
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-09-10 05:15 AM
In what are you substituting this?
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-09-10 02:52 PM
Lingwisyer wrote:It is from an Object I wrote from scratch to show only the Revision name and date. I think the information you are looking for is in line 28, so you can look at the script you are working on for the change you want to make. You could also try posting at the GDL Forum, they should know more about the than I do. As I said it works, but with an error message when the settings dialog box is open.
David wrote:In what are you substituting this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-09 02:47 PM
Thanks for pointing out the LAYOUT_CURRENTREVISION_OPEN command. This code now works for me without the error message:
If RevOrDoI = "Revision Manager" Then If LAYOUT_CURRENTREVISION_OPEN = 1 Then Text2 0, -Text_Y*.5, "W.I.P." Else Text2 0, -Text_Y*.5, LayoutRevHistoryDA[vardim1(LAYOUT_REVISION_HISTORY)][4] EndIf EndIfDavid
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-02-12 04:59 AM
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-02-12 02:43 PM
Still works here (on Master Layout).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-02-13 03:00 AM
Ling.
