If you have this many duplicates that usually comes about when the whole ArchiCAD Library is loaded twice.
If the ArchiCAD Library 11.LCF (library container file) is extracted then maybe the program loads both the LCF file and the whole library located next to it.
As Matthew said: check the Library Manager.
