Bob Moore
Library Loading
When I open an Autocad drawing (usually from a surveyor) none of the Archicad Libraies load. I go to the library manager and reload them but the walls, patterns, surfaces, etc. are not loaded. Any suggestions?
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
TomWaltz
Those settings are part of individual PLN files, not of the library.
You can MERGE, instead of OPEN the DWG files, which may give you the results you are after. This imports the DWG content into an existing flle.
Tom Waltz
