2016-10-16 09:48 PM
2016-12-09 10:20 AM
laszlonagy wrote:Will test this asap. The LOD is cool but what I need is a way to feed IFC parameter values from the original IFC-object to my gsm. I've got an IFC- model with almost 1000 objects, coded and everything and I'm trying to figure out how to make the conversion process as smooth as possible. I've extracted the IFC-params that are supposed to be the name of the object and then we have a small script that changes the stupid generated names in the folder...Furnishing 45 to 345-0 Xray_345-2...but we can't get any params but I figure AC20 can do this though the excel wizardry.
If I remember correctly this Add-On creates box shaped holes in Walls when creating Doors and Windows.
So if you want something different you will have to take what is automatically generated and modify/add to the scripts.
Normally the creation of a non-rectangular wall hole is relatively easy. This article may help you in that. I hope it works also when you save the result with the Library Part Maker:
http://helpcenter.graphisoft.com/guides/archicad-20/archicad-20-reference-guide/elements_of_the_virt...
But if you want to use splayed wall holes you will have to script it I think.
The thing to know about this Add-On is that it is good for the fast creation of many different GDL OBjects, but it has its limitations as to what it can generate automatically, such as in this case.
2016-12-22 02:48 PM
2016-12-25 11:50 PM
