I will ask the obvious here.
Are you using the door tool or the object tool?
If the door tool then you will need to check that you have the correct library loaded.
The default Archicad library definitely has doors.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
