Library is missing doors
I just installed the new ArchiCad 13 64-bit version.
I tried to add a door to my wall, I noticed that the library doesn't have any doors. Any fixes?
1 REPLY 1
I will ask the obvious here.
Are you using the door tool or the object tool?
If the door tool then you will need to check that you have the correct library loaded.
The default Archicad library definitely has doors.
