Library part not converted properly - 64bit
I've just changed from a 32bit to a 64 bit computer.
I am getting a "library part was not converted properly(W001)" warning when I try to use 3d. How do I convert this over to 64 bit?
Also, how do I find W001 - I assume that it's a window, but as I cannot see it, where is it?
Thanks as always for your help - any help is VERY much appreciated.
Regards,
Hayley.
6 REPLIES 6
David Maudlin
Hayley:
The "W001" should be the ID, you can use Find & Select to set up Window and ID as criteria to find the window (if that is what it is). The problem with window may or may not have to do with 32 bit vs 64 bit, this error message can appear under other circumstances.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Thanks David,
How do I solve this problem of not been able to see it? Is there a way to convert it?
Thanks,
Hayley
David Maudlin
Hayley:
If you can select the object, go to File > Libraries and Objects > Open Object... to open the object, then try Saving or Saving As... the object, this will convert it to the version of ArchiCAD you are using (making it unusable by earlier versions). This may correct the problem.
David,
As I cannot see the objects, I can't select them I tried in both 2D & 3D.
It took me absolutely ages to create them in the first place. I used the cabinet builder in cadimage.
I know that the objects are still there because when I put it onto a 32 bit, they appear.
Thanks again,
Hayley
David Maudlin
Hayley:
You best option may be to contact cadimage, they may have some insight into the problem.
God luck,
Hi David,
Thanks for all your efforts - finally solved the problem!!javascript:emoticon(':D')
It was as basic as TURN OFF THE SECURITY SOFTWARE WHEN INSTALLING.
Simple - worked perfectly.
I'd also like to thank Ian at Graphisoft who came up with the solution. I was floored when he called me to see if everything was ok. I don't say it very often, but I was very impressed with the customer service.
Thanks again,
Hayley.
