Library part was not converted properly (fu - 014)
Hello .. i have problems with my archicad.. when i change anything in the 3d window every time displays one Warning! box and it says "Library part was not converted properly (fu - 014)" I have 2 choises : 1. Stop and 2.Continue .. i have to type 4-5 times Contunue to display all my objects... Can i turn off these warning or can i fix the broken gsm objects with some program ...
Thank you...
3 Replies 3
David Maudlin
limonov:
One thing you can try is to select the problematic library part and go to File > Libraries & Objects > Open Object... This will open the library part, now Save, this will update the library part to the ArchiCAD version you are running. This may solve the problem, you should keep a copy of these parts unaltered just in case.
You should tell us which library parts are giving this message (are they part of the ArchiCAD Library that came with the application, parts you wrote, 3rd party parts?). Also:
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
The warning can be turned off in your work environment settings;
Options... -> Work Environment... -> Imaging and Calculation
Still hope that you find the faulty object(s).
Regards, Juha
"fu - 014" is most probably the ID of the element so you can use Find & Select to locate in on the Floor Plan.
Then the test is to select it and go to the 3D Window. If the error message comes, that's it.
Then for double checking you can select everything except elements with this ID of "fu - 014" and the erro message should not come.
