Light fixture needed
Tom Krowka
Anyone know how to create a rope light? Strip Lighting that would go behind a big piece of trim at the ceiling and shine up toward the ceiling.
Or if there is one already created out there?
Thanks in advance.
Tom
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
5 REPLIES 5
Tom,
You could just create a luminous material surface and apply it to a slab or morph that is the size / shape of the LED strip.
Scott
What about the 'Area Light' object (lamp tool)?
It can't be curved but it can be a straight line.
I have never tried it so can't say if it is good or not.
Barry
Dave Seabury
Tom
Give this a try, should be able to control the lighting, but if you
need to change the spacing of the lights you will have to open the object.
David
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
Tom Krowka
Interesting ideas all. How does one create a luminous surface. That's a new one on me. Sounds like it would be an easy solution. I guess I can research that.
Tom
Thomas@wkarchwk.com
www.walshkrowka.com
Dave Seabury
The strip attached was made with LPM, If you can not get the lamp to work you may need to load LPM (Library Part Maker). David
