Look for objects with attributes deleted
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2014-11-28 09:46 AM
‎2014-11-28
09:46 AM
I have ArchiCAD 18, I made a project using some of my Texture, only that in the course of the project, some I did not need more and I eliminated. But now every time I open the file I get this error:
the problem is that I can not understand what object or surface which continues to contain these images, so you can edit. Is there some way to do this automatically?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-11-28 11:11 AM
‎2014-11-28
11:11 AM
If you select any single item in the list and click the info icon in the lower right corner of the Dialog (which is enabled only when a single item is selected in the list) the upcoming Dialog gives you info about what is using it.
With Textures you normally have to go to the Surface Settings Dialog and remove the assigned texture from the Surface.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-11-28 11:41 PM
‎2014-11-28
11:41 PM
thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-12-30 08:54 PM
‎2014-12-30
08:54 PM
What happens if you want to keep the assigned texture for a different surface in a master lib texture library ?
How can you move the texture to appropriate folder / file ? Lost on this procedure
Michael |:-)
AC 4.5 - 19 Build 3003 Full USA
Mac OSX 10.10
Mac OSX 10.10
