Looking for a standard door handle (Residential)
It looks like the D1 Entrance 17 (or any other door) does not have an option for a fairly common exterior door handle. Any one know of one?
4 REPLIES 4
This is not the one you are looking for?
No lock mechanism in AC17
Jay,
you can save your own handle and then load as a custom handle.
1 - Model or import model of the handle
2 - select the handle and save as door handle
> File menu
> Libraries and Objects
> Save Selection as ...
> Door Handle ...
Save in project library if the handle is to be used in that project only or save into your company library if you want to use the handle in other projects
Regards,
Scott
Steve Jepson
you might need to download a couple of them, convert them to morphs so you can delete the parts you don't want, and parts from another one, then save as a new model handle
