2007-06-15 06:36 PM
2007-06-15 08:09 PM
M wrote:I assume you are on version 8.1 or earlier, since these parts have been called DET and not MSA from 9.0 onwards? (Always post your AC version - editing your signature under the Profile link at the top of the screen is the easiest way.)
It seems that there is no way to resize the msa bolt head and nut objects. Does anyone know why, have a fix, or know where to find a decent bolt object.
mul2 a/(1 1/4"), b/(0 7/8")In the DET_AB_Head_Elev 11 part, insert:
mul2 a/(1 1/4"), b/(0 5/8")Save each part with a new name in your company library until GS releases an updated 11 library - if they see this post and make these changes.
2007-06-15 09:13 PM
2007-06-16 01:49 AM
2007-06-16 04:11 AM
M wrote:You're welcome... but something is amiss if you see MSA in front of any Detailer Library 10 part names. The current version of the ArchiCAD Library 10 (US) has DET in front of all of these, not MSA. Sounds like you have an old library or PLA loaded...
Thanks alot, I'll try both of your suggestions. I have version 10 - the library is called DET but the object says MSA in front of it's name.
2007-07-11 02:03 PM
This may be "a decent bolt object".nice bolt gsm Peter, thanku vmuch
I made this object a long time ago
and find it more useful than the MSA parts.
Peter Devlin
2007-07-11 07:24 PM
# 65857 - Nuts and bolts detailer resizing problem...along with some other bugs that have been around for a while...
2007-07-11 08:11 PM
2007-07-11 09:37 PM
2007-07-12 01:18 AM
