MVO - MISCELLANEOUS SETTINGS
maro
after I add BIBLIOTHEKEN 16 to loaded archicad library 23, in MVO is settings - MISCELLANEOUS SETTINGS FOR LIBRARY PARTS (ARCHICAD LIBRARY 23) is replaced OTIONEN FUER GDL OBJEKTE (ARCHICAD BIBLIOTHEK 16) - MISCELLANEOUS SETTINGS FOR LIBRARY PARTS (ARCHICAD LIBRARY 23) are hidden,
Thanks
M
Guru
Images?
AC22-28 AUS 3001Help Those Help You - Add a Signature
You should not load multiple versions of the Archicad library at the same time.
If you are working in version 23, load the Archicad 23 library and if you need to (because it is an old version file) load the migration libraries as well.
Also I would try not to mix libraries from different language versions.
