Masterscript is not affecting "wall opening oversizing.
jshuether
I have a custom door that I’ve created. Variables include:
SHOW_FRAME: show door frame
TF_W: top frame width
LF_W: left frame width
RF_W: right frame width
gs_upper_oversize: upper oversize
gs_left_oversize: left oversize
gs_right_oversize: right oversize
In the “Details…” of the object under wall opening oversizing:
Y+ = gs_upper_oversize+TF_W
X+ = gs_right_oversize + RF_W
X- = gs_left_oversize + LF_W
In the master script:
IF SHOW_FRAME=0 THEN
TF_W= 0
LF_W= 0
RF_W= 0
ENDIF
The problem is, when the SHOW_FRAME variable is off, the 2D door symbol in plan still shows the wall opening oversize including the width of the frame, regardless of the fact that the masterscript makes all these variables zero. To get the symbol to show correctly, I have to change TF_W, etc. to “0” in the object settings dialog box which defeats the purpose of the quick boolean checkbox.
Is this a bug or a known issue? Is there another way to script what I am trying to accomplish?
ArchiCAD 25
Windows 10
Frank Beister
In case SHOW_FRAME is a checkbox:
Y+ = gs_upper_oversize+TF_W*SHOW_FRAME
X+ = gs_right_oversize + RF_W*SHOW_FRAME
X- = gs_left_oversize + LF_W *SHOW_FRAME
The opening into the wall is cut before any script of the window is started. AC takes the values of the parameter list for the calculation of the oversize fields, not the result of them at the end of scripot run.
jshuether
Vielen Dank, Herr Beister!
ArchiCAD 25
Windows 10
