Migrating highly modified template from 27 to 28
obim
Dear colleagues
We want to migrate a highly modified Archicad template from version 27 to 28. As this might be quite some effort we want to check with you if there’s any issues we should be aware of before doing so?
The team doing the migration is highly experienced in Archicad and is aware of all the standard tasks this project brings. So the questions are:
  • Are there known problems with migrated files after the migration?
  • Is the process with libraries still the same (regarding global library for example)
  • Our customer works with the Swiss template with the INT library: Are the elements of the INT library 27 the same as in the global library?
  • How will elements of the INT library 27 be migrated, if we’d like to work with the global library in future?
Thank you for your help!
All the best,
Oli
0 REPLIES 0
