‎2008-11-19 09:36 AM
‎2008-11-19 01:50 PM
‎2008-11-19 07:25 PM
Brett wrote:There is only a path when you select an object that is a duplicate - it lets you see where each duplicate is found. In the case of missing objects...if there was a path, it wouldn't be missing.
Hi, How can I get rid of this object missing error? It is definitely loaded. Why isn't there a path after the object name?
‎2008-11-19 11:38 PM
Karl wrote:
The fact that it is missing indicates that it is not.
‎2008-11-20 12:54 PM
‎2008-11-20 07:13 PM
Brett wrote:Sorry for the confusion.Karl wrote:Now you have me really confused.
Yes I can find it with the "find" library parts. Will search posts on GUID.
Thanks
Wiki wrote:So, what you need to do is find all instances of "Bolt 2" in your project using Find & Select. Here's the nightmare that you may run into: some of those may show up as bolts, and others as bold dots (missing object).
is there any feature loss?
The short answer is yes, there is.
Let's say for example that someone created a chair from 5 slabs and saved as a new .gsm but later renamed it and saved a new chair from 6 slabs with the same name so that the elements did not need to be changed one by one on the floor plan. The placed elements were matched to the new chair object by name, and the result was as the user expected.
From version 12 forward, the new element will have a new GUID, the textual name will not play a role any longer. The same scenario above would result in the placed chairs still referring to the 5-slab chair (even though it has been renamed).
‎2008-11-20 09:47 PM
‎2008-11-20 10:10 PM
Brett wrote:Missing objects are not just those that are placed in a project - they include the default settings of any of the tools. So, if the Object Tool was last used with your truss, it will show as 'missing'. Just select some other object out of the standard library with the Object Tool before saving your file and that will go away. (Happens for all object-related tools: window, door, skylight, wall end, label, zone, etc.)
On a similar note with the Library, I made a truss out of slabs etc and saved as an object. Then deleted it. Then I kept getting the "missing" every time I loaded that project. There is no instances of the object in the project. I just restored it to get rid of the library error. Is there a process more than just deleting out of the Library, to get rid of it altogether?
‎2008-11-21 03:23 AM
