Missing library part
Hi
I have a missing library part that is driving me nuts. I've searched far and wide for it and gone through all the various Find methods recommended in the Help guide to no avail.
Is there a way to force ARCHICAD to remove a warning? Or is there a way to "purge" unused Embedded objects in the model?
22 Replies 22
rob2218
great question.
if you get an answer.......that'll be awesome.
I'm surprised that Archicad hasn't yet figured out how to just have a "remove offending object" button or something to that nature that if the object is not there....remove it or an easier way to locate a darn object.
I wish the program had a scanning type function like when you can locate windows or doors thru the scheduler and see EXACTLY right where they are in plan.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
benjamin_chan wrote:
Hi
If it's in the model, it's not "unused." Is this a 3D object or a 2D object? (2D can be lurking in a section/elevation, or detail)
You might try creating a schedule for this object, which could tell you which layer/floor/etc. it is hiding on.
Richard
AC26 (since AC6.0), Win10
It's a 3D object.
I've had a look at the Object and the "missing" library part is not there.
It could also be a missing macro that the object is calling.
Richard
Any tips on how I would find that missing macro?
It might be good to end the suspense and include a screen capture of the error message.
Richard
See attached, many thanks.
What happens when you highlight the object and click on "More Info"?
Richard
No can do. It is greyed out even when offending object is selected.
