‎2005-03-29 09:57 PM
‎2005-03-31 01:55 AM
‎2005-03-31 03:16 PM
‎2005-03-31 04:07 PM
max_len = max (w_roonu, w_code) !*** width of the stamp
w_roonu = (stw (num_str)) * num w_code = (stw (code_string)) * codeNow you can look up the STW function in the GDL manual that comes with Archicad (as a PDF or in the Help files), and find out that STW returns the actual "model space" length of your text string, making it the perfect function to size your box.
num_str=" "+ROOM_NUMBER+" "Hopefully this points you in the right direction!
‎2005-03-31 09:10 PM
‎2005-04-01 02:59 PM
‎2005-04-01 03:16 PM
CU wrote:Its hard to tell exactly what this "SmArt" is but it looks interesting. Where can we find more info about it in english?
Try this : SmArT (m)
You can insert max eleven bawls
into desired order
Isn't perfect but even bad
‎2005-04-01 03:44 PM
Its hard to tell exactly what this "SmArt"??
Where can we find more info about it in english?I don't think so
‎2005-04-04 07:25 PM
Dan wrote:How is your Italian?
‎2005-04-04 11:57 PM
Djordje wrote:Unfortunately, I don't speak any Italian. It seems like this zone has some interesting functionality and I would like to learn more about. Maybe there's an Italian/English speaking member of this forum who could provide more information about this zone object.Dan wrote:How is your Italian?
This is a global forum.
