Have created a simple gsm object through typical AC process (3d window, save as object). Now I need to make some modifications to it. Typically I have kept the original elements from which I made the object and gone back and modifed them, then created the object all over again. Usually named it the same thing in the hope it would simply update the existing object. Sometimes it updates, sometimes it doesn't.
Why won't it update at times? And also, is there another way to modify existing objects without getting into too musch GDL mumbo jumbo? It would be very nice if they could be modified the same way a profile can be modified.
thanks
