2019-11-20 11:18 AM
rrr=REQUEST("Name_of_plan", "", prj_name, prj_fullname, prj_path)
zx = prj_fullname
parameters zx=zx
I feel like this should just work but doesn't, Any ideas as to how to solve it?2019-11-20 11:44 AM
2019-11-21 02:53 AM
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2019-11-21 03:55 PM
2019-11-22 09:50 AM
make the request in the master script and assign the result to a variable.This does not work in the Master Script because then the Master Script is used as Parameter Script and you get an error in the Parameter Script. (ARCHICAD 22)
then in parameter script assign the parameter's value to that of the master ...
2019-11-22 02:19 PM
2019-11-22 02:24 PM
2019-11-23 05:57 PM
if GLOB_SCRIPT_TYPE # 5 |GLOB_SCRIPT_TYPE # 6 thenThis only works for the output in 2D. The error message in Parameter Script appears nevertheless.
2019-11-23 07:10 PM
2019-11-25 02:54 AM
Moonlight wrote:
What about the autotext ? see above my responce
JGoode wrote:
What I want to achieve involves cutting up the name of the project to get the first 5 numbers of the project name. I have no use for it to be outputted in 2D / 3D. It’s not necessarily needing to store it as a parameter but I do need to be able to use the string (like a parameter). I don’t know if there is a way of doing so?
