Need help. What is this?
I am very new amateur user and still trying to learn how to use this software.
Can someone help me figure out what is this and how do I fix it? It keeps pupping out every time I star AC. Look at the attachment please.
MacBook
2GHz Intel Core Duo
1GB
AC10
2 Replies 2
You are looking at a "Library Loading Report"
that says you have two identical library parts
stored in two different folders of your loaded libraries.
If you scroll over to the right in the loading report
it will tell you where each is stored.
If you want to not have the error report,
you will have to remove one of the duplicates.
To do this correctly, please read this thread carefully
and follow the advice given.
http://archicad-talk.graphisoft.com/viewtopic.php?p=87700&highlight=lcf#87700
Peter Devlin
Thank you.
