Palawat
Need help for wall label
Hi everyone,
I'm working on a label (ArchiCad 17) for wall and need to know the Reference Line Location and Length of the Reference Line of the wall, so that I can place my label correctly. Is there a way to do that?
I know that REQUEST ("ASSOCLP_PARVALUE", expr, name_or_index, type, flags, dim1, dim2, p_values) exists, but I don't know what to put in "expr", or even if this is the right approach.
Thank you in advance
Archicad 29, Windows 10, Corei7 3.4 GHz, 32 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
2 Replies 2
Hi Palawat,
currently this cannot be done.
First of you are trying to use the code for extracting the info of an object-parameter, not a wall parameter.
Second, you can use the Globals 'Wall parameters - available for Doors/Windows, listing and labels' such as WALL_THICKNESS.
However WALL_REFLINE_OFFSET does not exist (BEAM_REFLINE_OFFSET does). This has been requested at Graphisoft.
Palawat
Thank you very much, Master Script.
I'm relatively new to GDL. Getting answer from the professional is very helpful.
