Learn more
Need idea for plan modeling
I been work few day on task to create a building plan. the issue is to make to layouts floor plan and penetration plan.
The problems is to present doors, windows and wall holes in right way.
in picture present examples.
It seems easy task. Not difficult to create one layout but to create other is quit difficult. Is necessary to change lot of settings. I looking to found way to save all settings on floor plan views and penetration plan view that it will be easy placed to layout.
1 Reply 1
Steve Jepson
If I understand what you want to do, it looks like you are on the right track.
I think you can use Model View Options, and different View Settings with unique Floor Plan Cut Plane Settings to generate the views you need.
