New users and error
I new user and I download Gdl Explorer.
Then start gdl explorer i see " gdl error object"
see image
I must gdl file because convert to 3ds file for max.
Help me
7 REPLIES 7
It is not clear what you are trying to do, nor why GDL Explorer is needed.
Are you exporting files from ArchiCAD to 3DS Max? You should be able to save from the 3D window in 3DS format.
I do nothing. I start gdl Explorer and show this error message. Why ?
TomWaltz
I think what Matthew is asking is WHY you are using GDL Explorer. What task are you trying to accomplish.
Are you converting Archicad to 3DS? You do not need GDL Explorer for this. You can simply "Save as..." in the 3D Window.
Tom Waltz
I download GDL Explorer and when first start gdl explorer I see this message
Why?
Do You know, help me
(u ostalom moze ako zna da mi odgovori i gosp. moderator Djordje, molio bi ga, traba mi ovo zbog studenata na faksu).
TomWaltz
Why?
We know that, you have already said so. You can keep asking the same question, but you will probably not get new answers.
We are trying to help, but do not what is causing the problem. If you tell us what you are trying to do, maybe we can help you find a way around the problem.
Tom Waltz
ok forget my post's
Djordje
Vlado,
Kontaktirajte hiCAD, oni ce vam sigurno pomoci.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
